hello,
Im using the latest version of Rhino - rhino 7 and I created a code on grasshopper which works perfectly. the problem is that when I am trying to insert a shapefile to the component of a shapefile - i am getting as error message like there is no data in the shapefile (which is not true). do you know how can I solve it?
Hello
welcome on the forum. It will be hard to help you with so little information. We have some Wizard but not like Harry Potter or Gandalf and no
Is ImportSHP your plugin ? If not which plugin ? What is the exact error message ? Is the SHP opened by other GIS tool ?
What is it ?
You could read that also
iirc importshp is built in.
hello
sorry if my msg was a little bit massy. i am attaching to this msg the grasshopper code i worked with. i used urbano plugin and inserted osm files and everything worked, but when i wanted to insert a shapefile (using the component of import a shapefile) i have got the error “solution exception cold not find file…dbf” why it wrote dbf if it is a shp file? and why it made this error if there is data on this shapefile
i am attaching the shapefile, the osm file as a link and the grasshopper code as a zip folder
thank you for your help
HAIFA_URBANO.zip (1.7 MB)
Hi -
See the FYI here:
