A Create Outline or Silhouette from a Make 2d object
Hi all, when I take a 3d mesh object and use Make2d to generate a 2d object of it, like the attached Hospital Bed, is there any way to create an outline of it that I can then use to quickly hatch it? Like a Silhouette of it…
Create Outline Challenge.3dm (1.6 MB)
Hi cosmas,
I can only think about it using Grasshopper solution. Should be possible with scripting also.
Best regards,
Pavel
I think this discussed here
For those of us who are not Grasshopper-proficient, is there any way to do this with a script or python file?
No need for scripts or any kind of automation really. Just select all, run CurveBoolean (DeleteInput=All if you want to get rid of all the interior stuff), then click in a space somewhere outside the entire figure and Enter. That will get you just the outer boundary, which you can then hatch.
That’s perfect, Mitch. Thank you so much!
