8 Rigid Body Modes Error
I tried modelling a simple 2d truss in Karamba3d, but for some reason I got this error no matter what support I put in it
  1. There are 8 rigid body modes in the system. This means some parts can move freely without causing deformation.
    Try to use the ‘Eigen Modes’-component and activate the display of local coordinate axes: The first eigen-mode will be the rigid body motion.
    If this does not help, check whether you have a pinned support directly attached to a hinge. A hinge introduces an extra node which may cause the problem.
    When analyzing a flat shell structure one has to lock the rotation perpendicular to the plate in at least one node.
I tried the simplest configuration to see what went wrong but I couldn’t find any, has someone encountered this problem as well ?
Simple Truss 1.gh (48.0 KB)
Hi, if your upper and lower chords and two end posts have their joints released, then you have a kinematic system and the structure is not stable, therefore it is giving you this warning.
