5 Sided Hole
How should I proceed?
Please help in rhino6 format.
train_1.3dm (373.0 KB)
Hi @hunterofrhino
The quick way is to DupEdge the highlighted edges
and then build a Patch using the curves for those edges and the edge of the surface from the remaining surface (with Adjust tangency" turned on)…
and then Join…
HTH, Jakob
I’m looking for a solution other than Patch, thank you for your help.
The not-patch answer is to rethink how you’ve made this. Running into a “5-sided hole” generally means I’ve made a mistake. No exact solution exists to what you’ve set up, no matter what you do it’ll be a “patch.”
Ideally NURBS objects should be made out of larger “rectangular” surfaces that you trim off intersect, not by making a wireframe and trying to “fill it in.”
