I’m having a spot of bother getting a decent surface/surfaces into this five sided hole. I’ve tried dividing it to get two four sided regions but that didn’t work too well (couldn’t get it smooth).
It’s the kind of problem the real experts do in there sleep but it still stumps me. In the past I would’ve just chucked a patch in there but I’d like to do better.
check out sky greenawaldts videos series… he gives several solutions to this that are the industry standard for handling this particular modeling problem.
If you want to throw tech at it, xnurbs is the ticket.
I’ve watched every minute of Sky’s whole series of videos and they are fabulous (actually I think there is the most recent one I haven’t caught up on yet). They really are the impetuous behind my trying to do it right!
Thanks, for the suggestion Stratofear. That’s a good approach.
I tried dividing where you have to get two four sided regions but I didn’t do the extended trim into the revolved surface. I expect that will give me more room to achieve smooth matches.
Thanks, thomas. Yes, that might work if I can get it to fit with the existing geometry. This is a modification to an existing component so I want to maintain as many of the original surfaces as I can.
When I have a bit more time I will return to it and see if I can work out how to do. Sky makes it look so damn easy in his videos (I know it isn’t all too well).
