The way I try to do it I convert model in nurbs, and then use command -Flow Along Surface,
but it didn’t work because rhino divides model into many surfaces and assign tiles to the one.
You’ll need to use DupEdge to duplicate the SubD edgeloops into curves. Then join those into the appropriate pieces for a NetworkSrf. This temporary NURBS surface can then be used as the target srf with FlowAlongSrf.
Your module has separate surfaces too with the normals flipped on some parts. Ungroup it a couple times to join the pieces first before flowing.
The PanelingTools plugin could also be used here but again you’ll need the base NURBS surface as a target for the grid.
