I’m designing a jewellery with SUBD (rhino 7 MAC) and it has smooth but elaborated curves. I’d like to use flow along surface to add my logo on the piece of jewellery. I think this should be the process:
- convert SUBD in Nurbs
- curve from object -> Create UV curves
- planar curves
- position my logo on the rectangular surface and then Flow Along Surface
It works, but after few tests I realised that the surface is actually only a small part of my jewellery piece, so the logo can only be very small.
Probably because the model is a polysurface.
My question: is there a way of having a larger part of the model when I select Create UV curves (like selecting not only a surface but a polysurface)?
or is there a better way to achieve my goal?
Thank you
