Hi, Rhino has a Text object command which makes a 3D piece of text in 3D space. Is there an equivalent in Grasshopper? All text commands seem to relate to text strings, rather than generating a Surface / Mesh…
Hello
there are many text tools in Grasshopper.
Grasshopper => Text on surface
Parakeet => output curves
Opennest => curves
Nautilus => output curves, surface, extrusion
Thanks. I was wondering if I could avoid even more plugins but I guess not
Cheers!
You can write your own C#, Python tool
Thanks Wim, looks like the kind of thing. What are the two components before Boundary Surfaces?
Text Entity and Explode Object.
File → 3D Text Objects.gh (5.6 KB)
Thanks, I don’t seem to have those. I’m in Rhino 6 - might be a newer version or a plugin.
Hi Derek -
That’s correct. Those are new in Rhino 8.
What is the sense in posting examples with icons when trying to explain a concept? This requires a previous knowledge of the iconography and is unsearchable.
Looks nice and minimal though.
