3d solid text cnc
Hi , I need to create a solid of a text starting from a single curve text.
i need to reproduce the subtraction solid that i would obtain if i cnc engrave the single curve text by using a cnc engraver and a round head tool of a given diameter.
the problem is that when i use the single curve generated in rhino with image font
and then pipe it i get sharp edges and the solid text layout is messed up.and not resembling the cnc engraved text
i made some search but i could not find relevant thread on this .
if anyone can help i appreciate
Seen this?
Awsome @martinsiegrist , meanwhile i made some attempt and i will post it below but your solution is definitely better .
can i ask you one favour : 1 i never used anemone / 2 i am not used to icons , can you post the defition on this thread ? How to Simulate Gcode - #8 by martinsiegrist
thanks
Thanks. The file is there:
Hello
You can explode curves and used rounded ends.
Or use offset from Clipper.
great but now the single letters overlap
the text was referenced as multiple curves directly from rhino, id like to be able to control the space between letter.
I tried (1) to flow along a curve to increase the space between letters but this works pretty much like scale1D thus scaling also the letters.
i also tried (2) to sort along X and then move the letter created with pipe but for some reason i am not able to get it to work since the trasformation is messed up
20260109 engraved text.gh (15.3 KB)
For text generation there a spacing parameter. It is a problem that you should take care at the beginning.
Here an example in Nautilus plugin, but must be there on all tools.
I have a tool to pack like you want but I think it is not the solution to your problem
@laurent_delrieu has a tool for everything :slight_smile:
Indeed not, this tool here will just work on a group of letters no on a whole lettering problem.
I use this one a lot in order to inspect objects before nesting. I will more an more do laser cutting (I bought C02 and fiber machine) so I will surely have to make some new tools :slight_smile:
thanks @laurent_delrieu , yes , i used Nautilus component to create the text and to adjust the spacing and and its very useful and practical
I also tried your ‘Pack Geometry…’, it’s amazing, but I still face some problems. Since the ‘8’ is composed of two closed curves, I agree that adjusting the text parameters is the best option though
@martinsiegrist : Laurent and You are both impressive , Your helpfulness and expertise are incredible
many thanks
@laurent_delrieu by using your useful suggestion i nearly reached my goal but now i am stuck in the solid difference , some of the subvolumes are not subtracted
beside this to work with solids is quite computanionally expensive…i wonder if the solution could be using meshes but i realized the Gh does not have a component for mesh solid difference
ENGRAVED LABEL SIMULATION.gh (22.9 KB)
i found this solution , it seems to work but @laurent_delrieu @martinsiegrist i wonder if you have any better suggestion
sorry i realized i was wrong , i used shrinkwrap to approximate the engraved text and then mesh solid difference and it seams to work reasonably ( i forgot to mention that my goal was to create a 3D printable label so working with meshes is fine for my purposes)
ENGRAVED LABEL SIMULATION 2.gh (20.3 KB)
