Ive imported an illustrator file and im trying to create a file to 3d print.
there is text in the file.
I extrude the text up, then cap them (tutorials helped me up to here)
Now how do i make the centers “hollow” like an O or an A. havent had luck with trim etc.
Hello - yeah, it will look different on the mac but the command line options should be there in some form - also, using Solid (pulldown menu) > Extrude planar curve > Straight will get you the solid extrusion IF the curves are closed, planar, and not self-intersecting.
Not at all - font curves are notoriously bad - fine for drawing text on screen but lousy from a surfacing point of view - poor continuity and often self-intersecting. The requirements are just not the same.
