My 3D mouse is not working anymore after the last update. The 3D Connexion line in the otpions menu disappeared and the Plugin is not enabled.
Rhino 8 SR15 2025-1-19 (Rhino 8, 8.15.25019.13001
Thanks in advance
Thanks in advance
Tried also with the latest SR downloaded from Rhino site with no better result.
System info:
Rhino 8 SR16 2025-2-11 (Rhino 8, 8.16.25042.13001
Windows 11 (10.0.26100 SR0.0) or greater
Ciao Enrico.
Running 8.16.25042.13001, 2025-02-11 here and my 3d connexion SpaceMouse works.
Can you run the SystemInfo command and paste the result here?
This tool is to check gamepad inputs, but works also with my 3dconnextion SpaceMouse Wireless
Do you have a similar result?
Hello Riccardo and thanks for your answer.
I solved it. I had to disable the load protection on the 3D connexion plugin (I don’t know why the protection was enabled after the last update).
Ciao.
