I use several 3d cad programs with Rhino being the most frequent. With V-8 for windows, the 3d connexion mouse orientation is completely flipped and it will not correct regardless of the settings?
The mouse works perfectly, in Sketchup, Fusion 360, Vectorworks and Alibre Cad. It used to work perfectly in the older versions of Rhino?
Does anyone know if there are Rhino settings that I need to change?
I just discovered (thanks to your help) that there is a command prompt “3dconnexion that brings up the menu. It seems that Rhino doesn’t need the 3d connexion software to work. Its somewhat built into the software.
