After a long day of converting solids to dxf, these files all seem to have vaporized…
They are not hidden. Some parts i did still see after finishing my work, and now they are gone too.
The bending lines are there still (were in their own layer) but the other layers where i put the dxf files seem to be empty.
This was already not a great day, because of the extra work the cnc company asked me to do becaise their machine couldnt read some of the rhino files. This is why they asked for dxf.
Open the fille. Unhide to ensure nothing is hidden. Turn on all layers and sublayers.
Ctrl-Alt-E or Zoom > Extents The view will zoom in/out and pan so that all objects are on the screen. It is possible to move objects a long distance away by mistake. This will help find those objects. It is possible that if the object is fare enough away it may not be visible.
How are you “converting” to DXF? DXF files can’t be stored on a layer. So I assume you are doing something to the “solids”, putting the result on a layer and then exporting them from there? If you detail your procedure, maybe someone can spot the problem.
So here we see that you have 219 deleted objects and 53 block definition objects.
Have a look in the Undo Multiple window (but don’t undo anything yet!) and see if there are recent undo commands that might have resulted in some of these. If you think that you have something to recover, make a copy of your file and open that in Rhino, run the undo steps until something reappears and then export that something (as a Rhino model) before doing more undo’s, in case they remove the recovered item again. If you do get useful stuff back then import it into the original model.
Next, open the Block Manager and check the count for each block listed. If you have blocks with a zero count look at the properties and preview to see if they look like missing pieces. Use Insert Block Instance to reinstate any you want.
It might be that McNeel support have a way of undeleting the 219 deleted objects to see if any are your missing bits. Or Mitch might have a tool in his extensive array of code snippets. @pascal, @Gijs, @Helvetosaur? [Edit: wrote a script that does this, see later post]
In the meantime, you could check the Recycle Bin for older autosave backups.
