2 forum accounts
Ive had an account on this forum since it began. I was recently invited to Serengeti, but given a different login. So if I log in with one I miss the new messages in the threads I was originally part of, if I log into the other I don’t get Serengeti threads. Can I combine them some how or get better access on my original login?
thanks,
Nick
I gave your account access. What is your other “new account”? I can delete that one.
Hmmm. I have an old one that I have been using since Rhino started on Discourse. The user name is my home email “its.nscott(at symbol)gmail.com”. The new one you gave me has a my work email as a user name: nscott(at symbol)sala.ubc.ca.
If it can’t be changed I will just only use the new one.
Nick
No; I will get rid of the new one. It is better to keep your old one around.
Great. Thanks!
Hi, I have the same problem. I log on the forum with the new rhino account created for rhino 6 licensing. I used an other account at my first log few years ago but unfortunately the professionnal email address used at that time doesn’t exist anymore.
Is there a way to “associate” the old account to the new one to keep tracking my old posts?
Thanks
@BaptisteCo there is unfortunately no easy way to do this since the discourse source code is not controlled by us (McNeel).
If you really, really want this to happen… then you would have to do a bit of careful surgery/juggling/magic to make it work:
Basically, you would need to remove ALL licenses from your “new” Rhino account, delete the “new” account to free up its email address. Then login to your “old” account, and add the “new” account’s email address. Then add the “new” account’s licenses to your old account.
You would lose all the posts of your “new” account, but you would end up with a single Rhino account.
If this is still acceptable, let me know and I can guide you with specific instructions.
Thank you @aj1,
I found a way to connect to the old mail address. It’s redirected to my new one, so I could modify password and authentify into “Rhino Account”. Then I logged in this forum, which connected to the old account. I just be careful not to log out otherwise it will take back the new rhino account.
It must be enough at the moment. I mostly needed to keep direct access to my old posts.
I apologize for resurrecting this issue ~8 years later, BUT…
I have my new work account (this one)
I had my old work account (last job…)
I have my personal account (same name, gmail)
According to Discourse’s documentation, as of 2023 accounts can be merged. Is this something that we could get done on my profiles?
I’d be fine with just rolling all of them into the personal one.
Did your issue get resolved?
I don’t have two (or more) accounts but did add my new e-mail address to my account, made it the primary, removed the old one and it keeps insisting on using the old e-mail address for login into this forum because it can’t find the new e-mail address even though the new one got verified.
Contacted forum support but no response so far.
If your issue did get solved then it seems easier to create a new account with my new e-mail address and then ask for the two accounts to be merged.
Yeah I got assistance from the McNeel admins to get it sorted out. @Japhy was able to get my three separate emails rolled up into one account, as far as I can tell :slight_smile:
