_intersect and _project are both not finding the expected result, if the cylinder and the cone have the same height.
(enlarging the intersecting surface or extending the line will give the right result)
intersect_Problem.3dm (88.1 KB)
Hi Tom - I see that, thanks.
https://mcneel.myjetbrains.com/youtrack/issue/RH-36471
Another Intersect, that is not working as expected
not sure, if this is the same bug
intersectProblem.3dm (38.3 KB)
Another problem found here:
and here
maybe it s the same problem in the code…
thanks for fixing it.
best Tom
Hi Tom - thanks - I see this is broken in V5… works as expected in V6/WIP. Progress.
