(Bug) Intersect Surface Surface does not find point
intersectionbug_v8_2023-10-19.3dm (3.4 MB)
surface surface intersection does not find points
to repeat - attached file and:
_intersect
intersecting a sphere and a trimmed 5-sided surface → no result
_dupFaceBoarder
intersect the curve and the sphere → 5 points
(not in the file)
_offsetSrf inwards by 0.001
_intersect 5-sided surface with new Sphere → 5 small curves
same behaviour for the 2 squares.
I really think - stuff like this should work, before V8 is released
there are other topics that are maybe related
another fail of intersect.
_intersect the green dices - no result
do some testing with edges / additional curves → the boxes share exactly one point, far beyond document Tolerance.
intersect_bug_v8_dices.3dm (3.1 MB)
@pascal
@Gijs
any chance this topic gets some attention ? thanks
I tried in Rhino 6, 7 and 8 but neither will give me intersections, did this ever work on your end?
not sure.
(I would guess yes it worked, but don t want to claim it)
but it should. - don t you think ?
I guess it makes sense, the reason I asked if it ever worked is because you said ‘should work before Rhino 8 is released’, which made me think this got broken.
Apparently I have never ran into a situation where this was an issue, but I agree it is cleaner if point intersections are found.
RH-78423 Intersect does not detect point intersection
Hi guys,
You made me curious so I wanted to test this out with a scripted RhinoCommon function. Because you see, the method Intersection.BrepBrep() is supposed to return points (if there are any found).
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.intersect.intersection/brepbrep
But it never does in any of my tests in 6, 7 or 8. So if the RhinoCommon method fails, I assume the underlying method it is calling is what is failing, which is why Rhino’s native Intersect command also fails at this.
I added a comment to this effect to the youtrack item.
