Hi all,
I’m trying to trim a Mesh but can’t figure out how.
With a brep i would do:
Dim Splitted As Geometry.Brep() = BrepToTrim.Trim(Trim.Brep, doc.ModelAbsoluteTolerance)
How to do this with a mesh?
-Jordy
Hi all,
-Jordy
You can maybe use Mesh.Split(…) to split a mesh with one or more meshes. Then use a BoundingBox or size test to decide which part to keep.
http://4.rhino3d.com/5/rhinocommon/html/M_Rhino_Geometry_Mesh_Split_2.htm
http://4.rhino3d.com/5/rhinocommon/html/M_Rhino_Geometry_Mesh_Split.htm
Was thinking of the same. But it could be easier if there would be a function like the brep one
How does the size test work? Never heard of it ^^
Size test: number of vertices, faces. If you know you are removing the larger part and trimming the smaller part, just counting vertices or faces can be the fastest decision to know what to keep.
Ah like that. Also a good idea but I dont know if which one is bigger
but thanks for the tip
