i am rhino beginner and have some problems to built my design in 3D.
Can you help me to create at first a surface between 2 profile curves and one rail curves.
i have a drawing of my design and a screenshot from my rhino file.
Maybe there are better ways to create this design??
ones more: on the drawing, you can see “layers” (on the top), so at the end, the model should built with this layers of 15mm, so you can see “stairs” between the layers.
Then cut 1st and 5th bottom lines and connect to the halfs of the"corner".
Check how many points on 1st and 5th bottom curves have. Simplify as much as possible.
Rebuild 1st and 5th top curves to match with points on bottom curves (makes better qualited surface)
Sweep 2 rails.
8 Side view, draw lines to cut surfaces. If slices outern sides must be straight, then just extrude the edges straight you made earlier. Then create surfaces between extruded slices, and cut off outer and inner parts.
