Mesh to Surface
Was wondering if there is any way to go from a mesh to a polysurface or surface “other” than using T-Splines? This is a long shot and maybe just a wish for the next version.
http://discourse.mcneel.com/t/reverse-engineering-convert-mesh-to-nurbes/24470
It is a topic that is regularly discussed, the above link is just an example.
Since I am waiting for my T-Splines to update, hence on my Mac. Can’t you do this in Windows Rhino?
That is only useful if the surfaces you are after are planar - it makes a plane for each polygon in the mesh - not (usually) what is desired in this context…
Thanks, I don’t really work with meshes, but i remember this command for some reason.
«Randy
hit the resources on the rhino site, look for reverse engineering resources in the left side tab-
http://www.rhino3d.com/resources/
Reverse engineering is a complex task. Take a look at
www.mesh2surface.com
It provides features and tools to help in this tough process.
