Are there any alternative ways to initiate the default.Popup window? I use multiple programs in my workflow and I use the middle mouse button to navigate/manipulate the viewport in each so I’ve set up Mac Rhino the same way. On Windows Rhino it can be initiated via the click and hold delay mechanism so you get both the viewport manipulation and the default.Popup via the same mouse button.
Ideally I’d like the flexibility of being able to initiate the default.Popup in the same manner as Windows but it would also be good if it could be initiated via a keyboard shortcut or via a modifier key/mouse button combination.
You can change PopUp to any other tool palette name if you wish. You can attach this to a mouse button with Rhinoceros > Preferences > Mouse > Buttons. Use Rhinoceros > Commands and use the Keyboard Shortcuts tab if you want to attach a keyboard shortcut.
Many thanks for this Marlin. I’ll give it a test after the weekend and see how it works for me. Also, I noticed your other response to my general thoughts on the Mac UX. I’ll reply to this on Monday too.
the script worked perfectly until I downloaded the latest release of Rhino Software information…
Now the middle mouse popup brings up a menu with text and icons again (a long list which needs to be scrolled through- please see attached image). Is there any workaround?
Cheers,
Anthony
Software versions
Rhinoceros version: 5.0 WIP (5A706)
IronPython version: 5.1.2015.131
Language: en (MacOS default)
OS X version: Version 10.10.1 (Build 14B25)
Plug-ins
None
Third party kernel extensions
None
Hardware information
Computer hardware
Hardware model: MacBookPro8,2
Processor: Intel Core i7-2675QM CPU @ 2.20GHz
Memory: 16 GB
Architecture: Intel 64 bit
Video hardware
Graphics: AMD Radeon HD 6750M 512 MB
Memory: 512 MB
Screen size: 1920 x 1080
Displays: Color LCD (147dpi 1x)
USB devices
Apple Inc.: FaceTime HD Camera (Built-in)
Dell: Dell USB Optical Mouse
Apple Inc.: Bluetooth USB Host Controller
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Computer, Inc.: IR Receiver
Bluetooth devices
Apple: Apple Wireless Keyboard
OpenGL information
OpenGL software
OpenGL version: 2.1 ATI-1.28.29
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
I can’t get the popup menu in rhino 6 for mac to come up using the trackpad. I tried configuring better touch tool to have a three finger click be the middle button, and in rhino i turned on the middle button to bring up the popup menu, but it doesn’t seem to be working…
any way to do popup with a trackpad on a macbook pro?
