Zoo lan not working
Does anyone has the same issue that clients cannot receive a license from a Zoo lan installation, firewall is open network is connected I even see port 80 being connected between client and server when I try to get a license, but still the client says Connectivity test with the Zoo server “servername(or ip) filed“. Client is W11 thino 8.29 server is W2022 with zoo 8, there are no errors in the client or the server eventlogs, and the service is running on the server with a license available.
Hi Fabian,
Here is the diagnostic utility.
Are you using a proxy perhaps?
Hi I solved the issue myself by allowing this in the firewall from the client to the server ‘soap(443,80,tcp)’ , maybe something to add to the guide or install manual of the zoo server.
This is what we have currently. If you were using different reference material says differently, please let us know.
" After installing the Zoo, you need to ensure that TCP Port 80 is open, for both incoming and outgoing communications, in the firewall software running on the Zoo server system."
Apparently 443 is needed too
