Zoo 7 service is running on Windows server 2012 R2.
No error in Event viewer Appl.
When running Zoo Diagnostics on the server:
PING
Pinging 192.168.17.6 with 32 bytes of data:
Reply from 192.168.17.6: bytes=32 time<1ms TTL=128
Ping statistics for 192.168.17.6:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
TRACERT
Tracing route to BIMSERVER.3rw.local [192.168.17.6]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms BIMSERVER.3rw.local [192.168.17.6]
Trace complete.
ZOOPORT
Error: No connection could be made because the target machine actively refused it 192.168.17.6:80
Running netstat -ano (on the server, does not list port 80)
IIS not installed, Java not installed, Windows firewall open inbound rule TCP 80. Symantec Endpoint Protection Manager ver 14 is installed.
This Zoo server have been working for several years, but after an Windows Update it stopped deploying licenses. I was running Zoo server 6 when this problem came up, An update to Zoo 7 server did not solve the problem.
ZooAdmin looks ok and lists several licenses available.
If I run telnet 192.168.17.6 80
I get no connection. This happens when running on the server and client.
That is strange or?
192.168.17.6 is the IP address of the server.
Sorry to take so long getting back to you. It appears that the Zoo Service is only binding to the localhost address (127.0.0.1) and not to your public IP address.
From Zoo Admin, click Tools > Options, and select “All” from “Bind to IP Address”
The Bind to IP Address “All” setting was already set.
I did however change it to the local IP address(192.168.17.6, only two options(All or local IP)) and after that the Zoo service not starting and I am not able to change the binding settings…
I seem to have messed this up, restart of the computer and repair of the Zoo server does not seem to help.
It looks like the problem here is that the Zoo 7 doesn’t run on Windows Server 2012 R2. I’ve logged this issue to make sure the Zoo doesn’t install on that platform: https://mcneel.myjetbrains.com/youtrack/issue/ZO-263
