Yak spec fails to get author, description & url from MFC plugin
Hi !
When running yak spec command on a freshly built MFC dll plug-in, yak correctly finds the RhinoPlugInName and RhinoPlugInVersion defined with RHINO_PLUG_IN_NAME and RHINO_PLUG_IN_VERSION but fails to retrieve other values, although defined.
Here is an example of output:
version: 1.2.3.4
authors:
- <author>
description: <description>
url: <url>
Would it be possible to fix this, please ? Am I missing something ?
Hi @Guillaume_Chereau,
I’ve logged the issue.
– Dale
Thank you @dale !
I just wanted to let you know that I’ve developed a custom “yak spec” tool for Rhino’s MFC plug-ins, and it works fine. Here’s the code snippet that loads the appropriate symbols.
Regards
#include <stdio.h>
#include <windows.h>
#include <string>
#include <vector>
typedef const wchar_t* (*FnW)(void);
typedef const char* (*FnA)(void);
struct PluginInfo {
    std::wstring name;
    std::string version;
    std::vector<std::wstring> authors;
    std::wstring description;
    std::wstring url;
    std::vector<std::wstring> keywords;
    std::wstring icon;
// main function
int wmain(int argc, wchar_t* argv[])
    // arguments
    // load rhp module
    HMODULE hModule = LoadLibraryExW(
        rhpPath.c_str(),
        NULL,
        DONT_RESOLVE_DLL_REFERENCES | LOAD_WITH_ALTERED_SEARCH_PATH
    if (hModule)
        wprintf(L"Loaded %ls\n", rhpPath.c_str());
    else
        PrintLastError();
        wprintf(L"Failed to load %ls\n", rhpPath.c_str());
        return 1;
    // retrieve plugin info
    FnW RhinoPlugInName = (FnW)GetProcAddress(hModule, "RhinoPlugInName");
    FnA RhinoPlugInVersion = (FnA)GetProcAddress(hModule, "RhinoPlugInVersion");
    FnW RhinoPlugInDeveloperOrganization = (FnW)GetProcAddress(hModule, "RhinoPlugInDeveloperOrganization");
    FnW RhinoPlugInDescription = (FnW)GetProcAddress(hModule, "RhinoPlugInDescription");
    FnW RhinoPlugInDeveloperWebsite = (FnW)GetProcAddress(hModule, "RhinoPlugInDeveloperWebsite");
    // fill info struct
    PluginInfo pInfo;
    pInfo.name = RhinoPlugInName ? RhinoPlugInName() : GetFileNameWithoutExtension(rhpPath);
    pInfo.description = RhinoPlugInDescription ? RhinoPlugInDescription() : L"<description>";
    // free library
    FreeLibrary(hModule);
    return 0;
