Currently, I use a CI server to test and build a plugin for Rhino and upload it to our server.
To distribute the latest version of the plugin without needing to edit the food4rhino page every time, I use a URL rewrite to redirect mysite.com/download/plugin.rhi to whatever the latest version is i.e. mysite.com/download/plugin_1.2.3.4.rhi. This technique works well, but I’d like to integrate a yak release into the project (and that way have food4rhino reference the yak package rather than the server rewrite).
From what I can tell there are two challenges here:
Get the CLI: The yak CLI is bundled with Rhino. Is there a way I can retrieve the latest version of the CLI on the server without Rhino? We use RhinoCommon from NuGet.
Authorization: Yak requires a Rhino Account login. Is there a way I can:
Generate a longer lived access token/api key (that ideally has reduced scopes), so I can store it in the secrets for the CI server
Provide an access token to the Yak CLI via a command
There’s a lot of appeal for us in having a non-customized server instance and installing all dependencies as part of the CI.
Has anyone got a cloud-hosted CI server creating builds for Yak?
To get a suitable auth token, run yak login --ci locally. This will generate a non-expiring auth token and print it to the command line. The token is scoped to the “yak” client, so it can’t be used for anything else related to your Rhino Account. In your CI environment store the token as a secret and set it as the value of the YAK_TOKEN environment variable so that yak.exe can used it.
I recommend not using yak spec in the CI build. Instead run it locally and add the manifest.yml to version control. In manifest.yml, you can use a placeholder for the version field, i.e. version=$version and the build command will populate this from the Rhino plug-in.
Perfect! Thanks for the tips, took a total of 5 minutes to set up.
(My search-fu definitely failed me this time - sorry!)
Would the best practice here to be to only offer the package via Yak? Will we end up with conflicts if people mix usage of the .rhi and yak package for different versions?
Yeah, it can cause problems because Rhino will try to load the same plug-in from two different places which can lead to a conflict. If your plug-in supports Rhino 6, then you may want to keep the .rhi around for those users. I think you can have both a package manager download and a file-based download on your F4R page – I’d get in touch with them to check the best way to go (food4Rhino or food4rhino@mcneel.com).
The build command has a --platform argument that might help here!
..\yak build --platform win
..\yak build --platform mac
Hey @will is there a mac download available as well?
I’m hoping to create a cross-platform multi-target Github Action for Yak and this would be fantastic
You can compile a MacOS compatible plugin from Windows, you would only need Mac if you need to compile native code (like C++).
What would be interesting for CI would be a Linux compatible Yak.exe so that you can use an Ubuntu runner rather than Windows. I haven’t tried it, but I believe you should be able to compile a plugin from Linux.
