Wrapping a strap around an object so that it looks realistic e.g. velcro or elastic straps
I’m trying to figure out how to model a strap over a last (shoe) model. I did a rough model and sketch here to show what I’m after… Basically, I would like the strap to go around the shoe but also wrap under the triangle shaped component so that it looks realistic. Any help would be appreciated :slight_smile:!
last model 1.3dm (8.9 MB)
I think I figured it out using sweep 2 but if anyone has any better suggestions let me know.
Assuming you have a surface for the shoe…
You could draw a curves for the outline of the strap. Then use those curves to split or TRIM a copy of the shoe surface. Then use OFFSETSRF to get the thickness.
For something like this, I would recommend SubD tools, if accuracy isn’t too important.
