I cant relocate the straps of a watch 3d model
Hello!
I have the 3d model of a silicone watch strap and it comes with the straps on a specific position.
My problem is that I want to make the model “flat”. simulating that the straps are on a planar surface like a table or something.
I’ve been trying to achieve that position using cage edit, but to edit the straps I have to detach them from the whole 3d model, and when I change it’s position the end of the strap that is united with the watch casing does not blend and they look like 2 different pieces sticked together.
Anyone know a command or process to get what I need?
This is the watch band 3d model.
And this is how it loks like with the cage edit
Thanks for your help!
Hello - please export that part of the model to a new file and post it here.
Hello Pascal,
Here Is the file with that part of the model
Strap issue.3dm (2.6 MB)
Hi Raimundo - is this after deforming? If so can I have a version from before? Or is the idea that you got the model like this and you want to fix it?
Pascal,
I’m attaching the model before and after the modification. As I said, the only way I fount to move the strap to the position I wanted was cage edit, but to edit that part I had to separte the strap ftom the whole watch band, but originally they are one piece.
Hope this help to explain my issue
Strap issue before-after.3dm (4.3 MB)
Hello - see if the attached file gets at what you need - the control object is a curve - I see this only makes sense in the Right view, since the strap is way off the Cplane, but you’ll get the idea.
Strap issue before-after_PG.3dm (3.0 MB)
Hello Pascal,
Yes thats what i need and coudn´t achieve when the strap was attached to the whole band.
I was trying to make it on the Right view too. How did you do it? Cpuld you explain me with images or a video so i can reply it to the original model?
Thank you very much!
Hi Raimundo - see the attached file - I made a line and rebuilt the line, and arranged the points as you see. If you use CageEdit and select this curve as the control object, I think you can get what you need.
Strap issue before-after_PG.3dm (2.5 MB)
Thanks for your help Pascal!
I was able to position them as I needed.
