Would love to be able to use any surface or polysurface as a clipping plane
that is all
You can use a lot of objects for Boolean subtractions and splits, as long as they at least bisect your object. I often split objects with a polysurface’s surfaces.
for now you can use this, it works very well for most cases:
http://www.food4rhino.com/project/dynamicdisplay
That is of course better than using of the simple clipping planes, however doesn’t have a functionality as asked by Wynott.
I would like generally to understand if it is possible and how big should be the effort if I would need to use surface or polysurface object for clipping purposes. Here I am talking about curved surface of degree 2 and above. Same goes for polysurfaces. Is it difficult to implement?
Thanks,
Dmitriy
I would guess yes - I think this is not something that is likely to happen soon.
This would obviously be used for generating cutaways like this:
Thanks, Pascal - fair enough.
Maybe smth will come in Rhino 7 :smiley:
Ryan, that is a perfect example!
Hi @stevebaer,
Any plan to include freeform clipping object in Rhino 9.X?
Thank you.
Kind regards,
Dmitriy
Not at the moment.
