Is there a way to merge alle the referenced worksession files into the master document? Would be good for export/convert the scene. Rightnow I have to import all the references by hand. I could do it via script but “WorkSessionFileName” only gives me the filename, not the path.
Hi Ralph - Is this script RhinoScript? try WorksessionModelNames() - does that get you the info you need?
oh yes, that does the trick, thank you
