Workflow Improvement Advice: Separate Inner and Outer Shell
Hi. I am attempting to machine a mold from this closed polysurface. I wanted to booleanunion this object from a block but cant figure how to make that work. What I ended up doing was deleting the facets attaching the top shell to the bottom shell and working from there.
Is there a simple way to separate that top shell from the bottom?
A faster workflow all together? I am a little rusty so any advice is greatly appreciated,
K
Hello- you can try this plug-in - if you set a high angle tolerance - maybe 45- 60 degrees or so, and pick a face on the front or back as a starting face, it should find all the faces on that side.
ExtractTangentFaces.rhp (40.5 KB)
You’ll need to unblock the rhp in Windows and then drag and drop it onto Rhino. I think this one is compiled for V7 +, not sure if it will run in V6. The command is ExtractTangentFaces.
Hey! Big fan of your work! Thanks for the speedy reply. I am using R7:
Resulting Command History:
Version of Rhino the plug-in was built for
does not match the this version of Rhino.
RhinoCommon SDK Version = 5.1.30000.17
Plug-In built for version = 6.0.18016.23451
Unable to load plug-in C:\Users\kevin\Downloads\ExtractTangentFaces.rhp
Well, hat is odd - that is the same one I am running here on V7.
But I am not sure what this means:
“RhinoCommon SDK Version = 5.1.30000.17”
Does Rhino think you have a V5 SDK? Have you bay any chance installed or reinstalled V5 after installing 7?
Meantime, until I sort out what is going on with the rhp, here is a Python version of the same thing -
ExtractTangentFaces.py (25.6 KB)
You can run that by
_-RunPythonScript "Full path to py file inside double-quotes"
It is a messy and convoluted script, from years ago, but I think it works.
BEAUTIFUL! THANK YOU!
And to answer the Rhino 5 or 7 mystery…I just upgraded from teaching license on Rhino 5 to commercial license on Rhino 7. Should I take action?
No, I don’t think so, yet, anyway… it just seems weird to me that the plug-in does not work on your V 7 but you get a message about the V5 sdk…
Let me run the compile again from V7- hold on a bit.
@kcook01 - see if this one works - I compiled it from V7.5.
ExtractTangentFaces.rhp (41 KB)
Oops! It was useful to delete the copy of Rhino 5 competing with Rhino 7. Too much Rhino energy. Everything is working great now.
I used to teach Rhino and whenever I would get stumped I would search and then see your name at the bottom of a very good answer. Thanks again for your help over the years!
