Wish: Select a directory to use the full Windows file browser
Could the Select a directory option in the “File Path” component use the full-blown Windows file browser?
Right now it brings up this monstrocity, which does not have a search function, quick access, etc.
If I go to search for a file, it gives me the proper file browser:
@kike is this something for you to look into?
E: Simple workaround for now is to get a file from the desired directory and then convert it to the directory path.
Hi @Intuos,
Thanks for reporting, it will be available on next Rhino 8 SR.
Awsome, thanks!
Can’t wait for this to eventually trickle down to Rhino.Inside.Revit as well.
@kike the stream panel contents also uses a different file browser than the fully featured Windows one:
Is this also something you could update?
Done on v8.12.
Thanks!
