There are two major issues with Grasshopper clusters that annoy me a lot.
The first is that the custom names set for cluster inputs and outputs change back to the default nested cluster component input/ output names whenever I insert a cluster in the document. This default name is the name of the input or output of the component to which the cluster input/ output is attached. The Pancake plugin has a feature to refresh cluster names, but why isn’t the name refreshed by default and why do I need a plugin for this?
The second issue is that when I actually rename the cluster inputs and output names, the text is cut-off in the description box:
Could be a high-DPI screen issue on Windows 10.
