I strongly believe it would be beneficial to have a small marker on the component either about the mixing mode, or at the very least if a component is using a custom mixing recipe. Maybe a small pink/blue drop on the component could be enough to hint a non default mix.
Currently, Remove Meta Data is by default removing, then adding the metadata with the default mixing behaviour. It should have a custom mixing by default (oof … and having the marker suggested on point 1)
I’m on holiday, I’ve logged it so hopefully I’ll remember to think about this later.
