Wish List: Grid snap for Grasshopper Canvas
I would dearly love to be able to set a “grid snap” style setting on the Grasshopper canvas so that it would be much easier and faster to align components.
A simpler version of the grid snap options in Rhino would be perfect.
I have the AutoGraph plugin installed and was very excited to try it, but so far I haven’t been able to get it to conform to the layout pattern I prefer for my definitions.
A very simple grid snap is all I would like to see. As it is I find myself zooming in and out all the time to tweak component alignments. I know it makes no difference to the performance of my algorithms but it certainly makes a psychological difference to the readability of definitions when I see components aligned together cleanly.
Hi Leo,
since components tend to have very different dimensions and often even different spacing between the input and output grips, I doubt that a grid snap is going to be very useful. What is needed I think is an object snap, like the current horizontal wire snapping but much, much better. It needs to pay attention to multiple wires, horizontal and vertical spacing, left/right/centre alignment of components and probably a few more things.
However maybe I’m confused about your suggestion, how do you see this grid snap working? Is it tied to the visible grid on the canvas? What corners/points of components snap to which points?
Also, don’t forget about Mr Sparkle. If you’re not already using these features..
Hi David, I can see from your reply that you’ve already put way more thought into this issue than i have, and I should just step back and offer encouragement for you to keep the issue in mind during your development work.
You’re bound to come up with something way cooler than what I was thinking of.
I was imagining something fairly crude, like the option to limit the component horizontal and vertical sizes to multiples of 5 pixels or 10 pixels or something like that. Then with say a 10 pixel grid snap function on it would be very easy to just line components up by eye like it is when you have grid snap on in a Rhino view.
Thanks Anders, I do use those functions regularly and they are very handy!
I agree with the OP… Grid snap would be very helpful.
  • Most components are standard dimensions with consistently spaced wires on one side or the other.
  • Some components have different numbers of input/output wires, in this case, the wires connectors would need to obey with the grid dimensions so they’re evenly spaced, not spaced to fill the component.
  • Re-sizable components (e.g. Panel) will snap to grid dimensions.
  • Components with the ability to add/remove connectors (via the +/- buttons), will need to top align and grow/shrink from the bottom.
Have you checked out SnappingGecko? Might be something close to what you’re looking for.
