Wish: Keyboard shortcut for Fold Definitions (Level 1)
Continuing the discussion from Rhino 8, Script Editor - Collapse to Definitions missing:
@Alain,
I would like the shortcut for Fold Definitions (Level 1) in the Script Editor to be the same as that in the Python Editor: Ctrl+Shift+ -
but in RH-78882 you state “those key bindings don’t work well on all keyboards”.
What keyboards are you referring to?
Please also (re)implement
Ctrl+K Ctrl+1
VS Code’s default shortcut for this command as an alternative. (Currently, Ctrl+1 toggles the Problems Tray regardless if Ctrl+K is first entered.)
Thank you
8.10.24226.13001, 2024-08-13
Hi Steven,
I meant keyboards with different layouts.
I’m in the middle of a major overhaul of the internals of the editor mostly to better support autocompletion but a side benefit from this work will be better support for key bindings.
