Wish: I’d like cage to work on surface points.
Do you want the Cage command to create a cage around surface control points?
- or -
Do you want the CageEdit command to work directly on surface control points? - or -
Do you want to something else?
I want the cage command to create a cage around surface control points.
Yeah, I think the same underlying problem as with FlowAlongSrf
and History is probably the culprit -grips are not top level objects that can be tracked in the same way. I was trying to hack a way with an intermediate point cloud - it might work, but looks like it will be way too clunky to be useful.
Pascal, how can your selection sets plugin keep track of sets of points, but Rhino history can’t?
heh… yeah… the script (and the new named selections in V7 I believe, @Trav, am I making things up? ) uses the ID of the parent object, the grip indices and holds onto that via user data. It does not track the grips as objects at all. I do not know, but I suspect the cage and flow stuff would need a significant amount of surgery to do that two stage thing and there is alost certainly a better way - like grips having Guids… or something.
Currently in Rhino grips do not have unique id’s only index numbers. Those index numbers can often change or be reassigned in a different order if the total count changes. This makes them hard, if not impossible to track throughout their life times. There’s a road map to make these objects have better tracking but it’s a long road ahead.
That’s unfortunate.
How does flowalongsrf work with points? I mean, it works once - no history - but it’s better than nothing. Can cage do that?
Hi Peter - Cage holds the original geometry in place for editing - every edit, the thing reverts to the original, behind the scenes, and deforms a copy to the new cage configuration and then replaces the last one. That way edits are not cumulative, if you see what I mean, in terms of densifying breps and approximations inevitable in the refitting. At any rate, since grips are not real objects or geometry in Rhino, the process cannot, if I understand things correctly, accommodate them.
Certainly from a user’s perspective it is a perfectly reasonable thing to want to do…
I sorta get it. Thanks.
