I use some GoogleWebFonts and I noticed, that Rhino _Text isn’t able to access the many different styles.
Try the very popular Roboto font for example (customize and check all the styles before downloading the zip):
or Roboto Mono which goes well with technical drawings:
There is only the “B” and “I” button for making it bold or italic but that feels like using a text editor from the 90s. Rhino is supposed to be a design tool, right? Hope we will be able to access the different font styles soon.
Or maybe it’s possible and I just have missed something here?
Do those fonts actually reside on your computer, or are they somewhere in the cloud? Currently Rhino can only access Truetype/Opentype fonts installed locally on your machine (as far as I know).
Yes, they are properly installed on my windows 10 system. When you download them as zip they come as TrueType font format.
Other design programs like adobe illustrator or affinity designer have a dropdown for the font and right beside it a second dropdown with wich you can access the different styles. No old fashioned “B” and “I” buttons there.
I know this will probably not have a high priority but I still think it’s a must have.
Oh dear. That is a slippery slope. “A design tool” is not the same as “the only design tool cause it does everything”, as much as we may want to conquer the universe. By all means keep asking (I have no idea what this particular request entails) … but on the other hand, don’t wait under water, as they say…
Hey, you’re totally damn right! I really hadn’t used rhino5 for a long time now, but yes, just tried it - all the different styles of a font are available in rhino5, just as everyone would expect.
So that means, that the absence of this in rhino6 is less a missing standard feature but more a bug, since it has already been there in rhino5.
I’m surprised that @pascal didn’t realize this. Hope it’s just a little tweak to bring it back?
It’s all in the system - no way to forget about it.
At any rate, if you check that YT issue, you will notice that it isn’t marked as fixed yet. You can pick font and style but there are still some related issues to work out.
I’m not sure. The YT item seems undecided.
From what I can see on my system, there are several style of a particular font available.
Are you missing font styles? If so, we’ll try to get the bug item on the road again…
I’m having this same issue 8 years later on rhino 8, the ttf font family shows, but none of the font’s styles (Light, Medium, Black, Condensed, et cetera).
You will find that different font families behave differently (for example Eras shows all styles individually but Lucida Sans just shows the family name). It’s down to how the foundries configure the fonts.
While Eras lays everything out on a plate for Rhino to feed on, Lucida Sans stays in the can and Rhino doesn’t have a tin opener (ironic analogy for an animal with a large horn).
Is there any way to open the metaphorical can so Rhino can use the font, or a workaround? I guess I’ll try exporting the text from illustrator and import it to rhino.
Taking the Lucida Sans example, there are four styles. One of the styles is Lucida Sans Demibold Italic. Demibold isn’t an accessible style name in Rhino, but if you apply the Bold and Italic options then I find that Rhino will actually be using the Demibold Italic style. As an aside, Word, for example, displays the proper style names.
I think what generally happens (under Windows, can’t speak for Mac) is that font families are split into different weights so that there are no more than four variants per font (equating to Regular, Bold, Italic and Bold Italic).
If you have a specific font that you believe doesn’t fit into this pattern, I’d be happy to take a look at it provided I have it or can download it without cost.
