Hi
I hope integrate it one Command in the future.
Extract For all Mesh and srf and …
This list is very distracting
It should be automatically recognized when you select what you want.
I counted them 23 lines ![]()
Thanks.
Automatically detecting will be hard. For instance if an object has a render mesh and an analytics mesh how would the command know which of the two to extract?
Having these as separate commands eliminates a potential source of bugs and problems.
You can have two commands.
One is when you are trying to get geometry… 99% of the time
- when you click a point, if there are multiple things under the mouse like surface or edge, there can be a selection menu popup.
Second, is ExtractMumboJumbo, which gets all the render mesh, analytical mesh, or whatever. maybe this has a radial menu.
In conclusion, Radial menus are the best when there are multiple choices like this. .
True, I meant such thoughts.
Or at least integrate Mesh commands with each other
