Hi there I’m using Rhino for quite a while.
After using ExtractAnalysisMesh of the Draft Angle Analysis results i want to select all the meshes by the color .ExtractAnalysisMesh gives to the mesh and not by its mesh wire color (which in this case is black).
Is there a way to work it out?
Hi Andre - I don’t know how easy it will be to make a reliable selection- if the object is very red or blue, the attached python may be able to distinguish well enough, but if it is at all close, it may get it wrong. I’ll try to think of a better way.
use RunPythonScript or
_-RunPythonScript "Full path to py file inside double-quotes"
Hello Pascal
With “If it’s all close” you mean that if the join meshes make a closed solid it’s doesn’t work ?
I’m having problems with the script you send.
I know who to run it by I’m a newbie at python so i can’t improve the code.
I just mean that if there is not a clear majority of red or blue, it may not get the right answer - it’s only counting the vertices that are blue or red and this may not correspond to the area of red or blue…
