[BUG?] Extract Render Mesh does not extract the rendered mesh (is not an identical copy)
I use often ! _ExtractRenderMesh
But in this case, discover that is not extracting the exact same mesh and is converting changing the mesh.
Enclosed the elevator of my J3CUB
I need the mesh that is rendered on the left and not the final result.
Deos not extract render mesh.rar (599.9 KB)
Hello - if your disply in the image is using the EMap command, the mesh you want is from ExtractAnalysisMesh.
Don’t you mean ‘ExtractAnalysisMesh’? :grinning:
Time for a coffee. Thanks.
I’m in rendered mode and the mesh change shape when ExtractRenderMesh.
I use the Emap just for the screenshot.
Thx AIW and Pascal: I try ExtractAnalysisMesh and is working well thanks for the tip!
So Is this a bug or I do not understand the meaning of extract render mesh?
I see that the rendered view of the object looks more like the extracted analysis mesh than the extracted render mesh - I do not have an explanation…
