Is it possible to limit the data flow while the Kangaroo solver is running? I have some relatively heavy operations that I perform on the solver’s result, adding a automatically opening and closing datadam would help in streamlining my script.
Yea that would be awesome. A Boolean (True = Converged) would be enough.
Although the ZombieSolver only passes data on when converged - without the visual iteration feedback.
You can’t pause it, meaning you can’t decide that the result is good enough to pass data onwards.
Hi @Intuos and @rudolf.neumerkel
Here’s an example showing a way to get the component state now
The problem with just a boolean output is that it won’t stop the downstream parts from updating.
Even if a value isn’t changing, if Kangaroo is refreshing as it solves it will trigger updates of everything connected to its outputs.
I think for this to be useful we’d also need a version of the data dam with a boolean input.
Yeah, what I think would be best is, since you need to refresh the solver anyways before starting, the reset and on input values could then also be fed into the datadam, which is only triggered once the solver stops (converged) or is paused (by the user).
I often do something like this when I have extremely heavy calculations to do after the solver:
it’s not automatically, but at least it speeds up the entire process.
I have now added a data dam with a 10s interval, will see how that goes/ scales the more data I feed into it. May have to add another data dam to get to a 20s interval.
Anemone ‘Classic’ Loop End has a right-click option to “Output after the last”.
Anemone ‘Fast’ doesn’t even have that option, it always works that way.
Yo guyz!
toggable Dam V0.1.gh (5.0 KB)
Maybe mix this with the boolean from Daniel’s script …
Note that, the “disconnecting event” occours after the wrong data flows, once.
So, you might want to filter that single “wrong impulse” like this:
Code:
private void RunScript(DataTree<object> Target, DataTree<object> Source, bool G)
if(!(G & oldstate == 1) || (!G & oldstate == 0)){
if(G){oldstate = 1;}
else{oldstate = 0;}
source = this.Component.Params.Input[1].Sources[0];
target = this.Component.Params.Input[0].Sources[0];
this.GrasshopperDocument.ScheduleSolution(5, SolutionCallback);
// <Custom additional code>
int oldstate = -1;
Grasshopper.Kernel.IGH_Param source;
Grasshopper.Kernel.IGH_Param target;
private void SolutionCallback(GH_Document document){
if(oldstate == 1)target.AddSource(source);
if(oldstate == 0)target.RemoveSource(source);
Very nice!
Thanks for sharing this
Here’s a test - first with this toggled dam, then without for comparison
toggable Dam V0.1_test.gh (20.9 KB)
Nice, with the topic link in a panel ![]()
It looks interesting. Could that be implemented in the next update ?
You can use the script.
I am doing it, it helped a lot, seems like something that should be integrated.
This is huge, it speeds up everything. It should really, really be part of the next update
