With _Loft _Loose, the construction curves (degree/control points) are turned into the V of the surface, but the U is always deg3. I’d like to be able to set the U degree as well.
It would work the same way as _Curve. Setting _Degree=11 and inputting 5 control points generates a single span deg4 curve. Setting it to _Degree=5 and inputting 7 control points generates a deg5 curve with two spans.
Setting _Loft _Loose _UDegree=5 would create a single span deg5 U with 6 inputs, a single span deg3 U with 4 inputs, or a two-span deg5 U with 7 input curves.
