Wish: cage turn degree 1 polylines into degree 3
If, for instance, I draw a square and then use cage, dragging cage points does not have any effect. I have to explode the curves, change the degree, rejoin, then use cage. Why doesn’t cage just change the degree or whatever it needs to do, automatically?
Hi Peter - it looks like it handles polylines this way but not degree 1 Nurbs curves - I can see how it might be good in some cases but I would expect it to still follow the PreserveStructure setting - I’ll see if we can get this tuned up, thanks for pointing that out - you can use ToNurbs on polylines and then CageEdit them to get them to ‘flex’.
