another wish:
When creating a box with “Box: 3 points, height” the height of the box is directed either in Z positive or Z negative direction, depending on the way/order you set your first 2 inputs (width and length).
So after specifying my first 2 dimensions and entering the 3rd one numerically, I am never sure that the box height is pointing in the right direction, in my case upwards from my construction Plane.
I would like this command to behave in a way that positive values for height should alway lead to the box being generated in the positive Z direction with regards to the CP, negative values should lead to generation in the negative Z-direction.
