Wireframe shown on other views
After I updated to Rhino 7 release 22, meshes and surfaces are often shown in wireframe for no reason.
(left is polysrf and right is mesh)
스크린샷 2022-10-04 17.05.52
so in shaded view it sometimes shows just wireframe.
also this keeps happen to other views like render for example.
i tried some solutions but i couldn’t solve it.
HELP. It’s really annoying when I work on stuff.
Hello- please post an example or send to tech@mcneel.com with a link back here in your comments. Pease also post the output from the Rhino command SystemInfo.
Hello, here I got a video for easier understanding. Sorry for low quality, i had to compress it for the upload.
So it randomly becomes only wireframed or just transparent in many views.
also system info is below.
Rhino 7 SR22 2022-9-12 (Rhino 7, 7.22.22255.05002, Git hash:master @ 196b1bc7dd093321e28dcc7a2bb8709a9bebe12d)
License type: Educational, build 2022-09-12
License details: Stand-Alone
Apple macOS Version 12.4 (Build 21F79) (Physical RAM: 32Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: MacBookPro18,2
Language: en
Apple M1 Max (OpenGL ver:4.1 Metal - 76.3)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 21845 MB
Graphics: Apple M1 Max
Displays: Unknown (255dpi 2x)
Graphics processors
Apple M1 Max
Color LCD (1728 x 1117 @ 120.00Hz)
USB devices
Realtek: USB 10/100 LAN
Razer: Razer DeathAdder V2 Mini
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Users/htl/Library/Application Support/McNeel/Rhinoceros/packages/7.0/ProRender/1.0.1.0/libRadeonProRender64.dylib
/Users/htl/Library/Application Support/McNeel/Rhinoceros/packages/7.0/ProRender/1.0.1.0/libNorthstar64.dylib
/Users/htl/Library/Application Support/McNeel/Rhinoceros/packages/7.0/ProRender/1.0.1.0/ProRender.Mac.V7.rhp “ProRender” 1.0.1.0
/var/folders/d3/shd1zcjn2z9d8fns3fv3bmxh0000gn/T/AppTranslocation/708E1903-0F04-43E4-89DF-41C79CBC5303/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.22.22255.5002
/private/var/folders/d3/shd1zcjn2z9d8fns3fv3bmxh0000gn/T/AppTranslocation/708E1903-0F04-43E4-89DF-41C79CBC5303/d/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.22.22255.1002
/var/folders/d3/shd1zcjn2z9d8fns3fv3bmxh0000gn/T/AppTranslocation/708E1903-0F04-43E4-89DF-41C79CBC5303/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.22.22255.5002
/private/var/folders/d3/shd1zcjn2z9d8fns3fv3bmxh0000gn/T/AppTranslocation/708E1903-0F04-43E4-89DF-41C79CBC5303/d/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.22.22255.1002
/var/folders/d3/shd1zcjn2z9d8fns3fv3bmxh0000gn/T/AppTranslocation/708E1903-0F04-43E4-89DF-41C79CBC5303/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.22.22255.5002
/var/folders/d3/shd1zcjn2z9d8fns3fv3bmxh0000gn/T/AppTranslocation/708E1903-0F04-43E4-89DF-41C79CBC5303/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.22.22255.5002
/private/var/folders/d3/shd1zcjn2z9d8fns3fv3bmxh0000gn/T/AppTranslocation/708E1903-0F04-43E4-89DF-41C79CBC5303/d/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.22.22255.1002
/var/folders/d3/shd1zcjn2z9d8fns3fv3bmxh0000gn/T/AppTranslocation/708E1903-0F04-43E4-89DF-41C79CBC5303/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.22.22255.5002
/private/var/folders/d3/shd1zcjn2z9d8fns3fv3bmxh0000gn/T/AppTranslocation/708E1903-0F04-43E4-89DF-41C79CBC5303/d/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.22.22255.1002
/var/folders/d3/shd1zcjn2z9d8fns3fv3bmxh0000gn/T/AppTranslocation/708E1903-0F04-43E4-89DF-41C79CBC5303/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.22.22255.5002
/var/folders/d3/shd1zcjn2z9d8fns3fv3bmxh0000gn/T/AppTranslocation/708E1903-0F04-43E4-89DF-41C79CBC5303/d/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.22.22255.5002
/private/var/folders/d3/shd1zcjn2z9d8fns3fv3bmxh0000gn/T/AppTranslocation/708E1903-0F04-43E4-89DF-41C79CBC5303/d/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.22.22255.1002
Hello- can you please send an example file to tech@mcneel.com, with a link back to this topic in your comments?
I sent an email
Thanks, I see your file - so far it looks good on Windows, checking mac.
@LHT - it all looks correct here on a similar system but with mac OS 12.6 - you might try updating yours which is on 12.4
Oh, I will try that.
Thanks for your help :slight_smile:
Here’s a bad news. Even after updating to 12.6, it still has the same problem.
I also wanted to try downgrading the rhino version to 21 but i found it impossible to get the installation file. (just because it happened after updating to version 22.)
Apple macOS Version 12.6 (Build 21G115) (Physical RAM: 32Gb)
Language: en
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Vendor Name: Apple
Render version: 4.1
Z-Buffer depth: n/a
Graphics processors
Apple M1 Max
USB devices
Bluetooth devices
None
None
Third party plugins
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.22.22255.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.22.22255.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.22.22255.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.22.22255.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.22.22255.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.22.22255.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.22.22255.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.22.22255.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.22.22255.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.22.22255.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.22.22255.1002
I have a stuff that i should start working on tomorrow or 2 days later, so please help me out.
I want it fixed badly.
Hi -
A few other things to try: I see that you are using non-default display modes - does resetting those to the factory-defaults change anything? What happens when you disable the ProRender plug-in?
Note that you don’t have to uninstall pervious versions on macOS - you just need to make sure to rename the icon when you unpack the dmg.
Here’s a link to SR21 - 7.21.22208.13002. Does that still behave differently?
Thanks for the help!
going back to version 21 solved the problem. so updating to version 22 definitely was a problem.
RH-70627 is fixed in Rhino 7 Service Release 24
