I tested to change wire thickness in the latest Rhino 6.3 version. I used the options / advanced / WireThicknessScale, and got very thick lines. When I wrote 0.6 I got 6 instead.
If I use the old testWireThicknessScale command instead I get the correct result.
Hello - thanks for the report. What is your location? Is your Windows set up for comma as the decimal separator?
Yes, but I used the scroll to set the parameter.
@pascal Is there any possibility to fix the problem with comma separator?
When I fill in a value using dot as decimal separator Rhino still uses a comma when I click OK.
I now tested it in version 6.3.18090.471, 2018-03-31
Hello - thanks for the details, I am checking on this. Sorry for the delay.
Hi @pascal,
I noticed this with the new setting:
I entered 0.6, closed the options, and when I re-open the options there are too many decimal places spilling over.
I just now installed SR4 and there are still nothing done to the problem with a comma instead of a dot.
Hei Per,
I see that here as well on my system. I’ve now logged this as RH-45956.
Bump
A month has passed on and nothing has happened
My office has got the same issue, and would also like this fixed anytime soon
Thanks, I gave the YT item a bump.
@pascal Maybe it’s time to bump again
Someone could perhaps make the priority higher?
Is John Morse no longer working with you?
Nothing happenes with this subject.
Hei Per,
A quick check in the tracking system shows that John has 150+ issues on his plate at this point.
As long as an issue has a workable workaround (in this case testWireThicknessScale) I can imagine that it won’t float to the top of the pile in a hurry…
That said, it doesn’t hurt to send a reminder once in a while.
Hei igjen, Per,
FWIW, I can’t reproduce the issue on my system anymore - the “.” remains a period and is not converted to a comma. Which Rhino version are you running at the moment?
wim
I’m running 6.10.18311
I checked just now and you are right, it’s fixed
Cool - Thanks!
150+ minus 1…
RH-45405 is fixed in Rhino 8 Service Release 11 Release Candidate
