WIP - import a point cloud - it's invisible!
WIP reset to factory defaults
New blank Rhino file in meters
Import a 4m point cloud (DEM file in .xyz format)
Import is successful (~10 sec)
ZEA shows nothing in any viewport
SelAll - 1 point cloud selected
Zoom All Selected shows nothing
Ctrl+C copy
Paste into V8, ZEA, pointcloud is perfectly visible…
WTH??? DirectX display problem? Looks like it, switching to OpenGL, point cloud shows up immediately… Note: running MeshPatch on the point cloud, the mesh shows up perfectly.
Will try updating my video driver and see if that helps… Nope. No change.
@stevebaer ?
Rhino 9 SR0 2026-2-3 (Rhino WIP, 9.0.26034.12305, Git hash:master @ f10eb7a75f4fc041d932b4ee5c7a6367183ae4eb)
License type: Not For Resale Lab, build 2026-02-03
License details: Cloud Zoo
Expires on: 2026-03-20
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 9.0.1
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 4070 SUPER (NVidia) Memory: 12GB, Driver date: 12-30-2025 (M-D-Y). DirectX(11)
- Secondary monitor attached to adapter port 0
- Windows Main Display attached to adapter port 1
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26034.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26034.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26034.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26034.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26034.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26034.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 9 WIP\Plug-ins\import_points.rhp “Points Import”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Hi @Helvetosaur,
Can you provide a file so we can attempt to repeat what you are seeing?
Thanks,
– dale
Link to file sent via PM…
Hi @Helvetosaur,
Looks like a DirectX issue - I’ve logged it.
– Dale
It’s a far from origin issue with Direct3D. If the cloud is moved to 0,0,0 it shows up. I’ll get this fixed
RH-92306 is fixed in Rhino WIP. Point Clouds should display now.
