unable to create a circle tangent to three curves; see attached file. where do I find ellipse curve creation in WIP 9.0…… ??
Art
Weber fastener fairing.3dm (87.6 KB)
Art
Hi @artesmith,
Your circle tangential to three curves isn’t giving the result you expect because the three curves are not in the same plane. Make them so and you’ll get a circle in the plane.
I don’t believe there is any tool for directly creating an elliptical arc - you either create an ellipse and trim it, or a circular arc and scale it. Incidentally there is a new ‘fit to points’ option for the ellipse command, in the WIP only, but you need to run it with the hyphen option, -ellipse, to see that as it hasn’t been added to menus or toolbars.
HTH
Jeremy
Jeremy-
thanks!! how do I determine/verify curves are co-planar? clearly the construction was undertaken believing the curves were all in the same plane…..
Art
Well, I’m on my laptop and suspected they weren’t co-planar from the command behaviour so I checked in the front view. But on my desktop with a large screen, I keep the Boxedit panel open all the time, so I can immediately see if a selection of several curves has height when it shouldn’t. If the plane of the curves isn’t parallel to the world planes you need to set a cplane and use the cplane option in Boxedit for this to work, of course.
This script might help:
CheckCrvsCoPlanarity.py (1006 Bytes)
To make them coplanar, a variety of methods, SetPt in Rhino is one of them if the curves are supposed to be parallel to one of the principal planes.
thanks guys!!
Art
must be thick. I’ve rebuilt the involved geometry and used “Setpt” to doubly make sure everything is co-planar; and “circle tangent to three curves” will have nothing to do with me……………… the updated file is below; haven’t tried the “-ellipse” command yet
Art
Weber fastener fairing.3dm (85.6 KB)
What I am noticing is that the Cen osnap seems to be getting in the way if you have it activated… I’m not sure why it would be if you are trying to do tangents… Seems like it should be “tuned up” maybe. In any case Cen has always been too strong IMO, I have it turned off almost all the time and generally only use it as a one-shot.
thanks guys!! operator was attempting to select in the wrong spots…….
Art
