Window layout bug
I’ve found another bug.
I wanted to load a default Rhino layout.
Previously I saved my layout 3 times to be sure to recall the previous one.
Unfortunately Rhino 8 WIP hangs as soon I select the Default Window Layout.
No crash, I must kill the app.
I’ve also tested the Window layout feature with the RTX2080ti
With the Nvidia gpu Rhinoceros crashes immediately.
Thanks for the videos gabrielefx,
I just tried to replicate on Windows 10 RTX 2070 & Windows 11 3070Ti with no success.
8.0.23251.10305 & 8.0.23252.17001
Please run Rhino WIP in Safe Mode (eliminating video config/3rd party plugin variables) and try again. Thanks
How?
What’s the procedure for the Safe Mode?
It is already reported to Mcneel, via this post.
[ERROR] FATAL UNHANDLED EXCEPTION: System.InvalidOperationException: Dispatcher processing has been suspended, but messages are still being processed.
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
[END ERROR]
I was able to crash Rhino in Safe Mode.
