Hi all. I am trying Conveyor plugin on evaluation and i came across an visual issue.
When I am using conveyor to bring a revit wall only, all the window wall are getting filled up with surfaces. I was expecting the windows areas in revit would show as holes in Rhino after import using conveyor panel. Is this normal?
I can faintly see the window outlines, are they on different layers?
Thanks @Japhy for replying. They are on same layers. The wall has three lyers in revit. When I ungrouped the wall in rhino, i could see only the core is punctured not the other parts.
I tried but noting worked out. It is a bug I guess
How are you importing? Can you post a screenshot?
Nathan checks here periodically if it is a bug.
If i get a chance later this week i’ll install my conveyor and test.
I will post a video if possible but for now let me explain. I opened revit file and started rhino inside from conveyor tab. Then i opened the rhino interfce inside revit. Than i typed convyer4 to get thr panel. Than i selected the wall in revit and clicked import from revit inside convyeor panel. Thats it !
HI @archinate1. Can you pls help me out here!
Hi @Japhy. Did you try on your end?
