Will this hardware configuration work? (for Rhino 6,7, & WIP)
Here are a few of the components:
Intel Core i9 13900k 3.0GHz 36MB,
ASUS GeForce RTX 4090 TUF OC 24G,
ASUS ROG STRIX Z790-E Gaming Wifi
Please comment!
What are we supposed to be commenting on here? You can’t really get much better specs without going to cost-no-object enterprise gear. I hope you’ve got more than 16GB RAM there.
Ram is 64GB. I Just wondered that the components being based in Gaming, may have a detrimental effect on some aspects of Rhino 3D.
No.
If you’ve got a 4090 I’d spec out 128.
What a waste of two PCI slots. I reckon you could fit another 4090 in there in the bottom slot, and maybe a two-slot 4070 between those. A 2500 Watt power supply should do it. :wink:
Nice hardware! Most envious.
I wanted to show you a performance run in Holomark2 just to demo the actual speed, but the app or plug-in freezes about five seconds in probably due to Windows 11 (there was no way to get Windows 10)…
But here is a peek under the hood … .
And the Case is on the big and heavy side: 10" Wide, 24" High, and 21" Deep (and weighs 55 lbs) called “CORSAIR”.
Given that I can run Rhino 7 or 8 WIP while debugging a plugin in Visual Studio with an 11th gen i3 and 8 GB* which shares with the onboard video, I’d have to say ‘yes, that should be adequate’.
*Temporary setup, it’s what the store had
A 13900K is probably (definitely) going to bottleneck under maximum all core load in any temperate climate. My 13700K is really on the thermal limit for air cooling. The TDP I think is ~250 W, which is the top limit of an NH-D15 or a Thermalright Peerless Assassin 120. In reality, as out of the box CPUs get usually boosted by the motherboard without undervolting, it can get to 280 W.
Holomark 2 had been updated such that I managed to run it fine on Windows 11 with Rhino 7, so I don’t know why yours freezes.
I started up the computer this morning and started up Rhino 7…and it completed Holomark2 in about 45 minutes. Here are the results:
Holomark 2 R6 v2,61
Total Score: 534038
Total Runtime: 2650.03 sec
GPU scores: 497220
GPU_01 - 1666.70 fps - Cube 4 tests
GPU_02 - 144.90 fps - UDT Shape
GPU_03 - 59.90 fps - Wireframe
GPU_04 - 59.90 fps - Shaded
GPU_05 - 60.20 fps - Rendered
GPU_06 - 59.90 fps - Block Rendered
GPU_07 - 2368 units Nurbs @ 5 fps in Wireframe
GPU_08 - 904 units Nurbs @ 5 fps in Shaded
GPU_09 - 184 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 60.20 fps - RenderMesh Render
GPU_11 - 59.90 fps - RenderMesh RenderSpeed
GPU_12 - 59.90 fps - JoinedMesh Render
GPU_13 - 59.90 fps - JoinedMesh RenderSpeed
GPU_14 - 258 units mesh @ 15 fps in Shaded
GPU_15 - 1535 units mesh @ 15 fps in Render
GPU_16 - 4492 units mesh @ 15 fps in RenderSpeed
GPU_17 - 60.20 fps - mesh in Rendered Studio
GPU_18 - 60.20 fps - Nurbs in Rendered Studio
GPU_19 - 60.20 fps - Block Illustration
GPU_20 - 60.20 fps - 2D single
GPU_21 - 60.20 fps - 2D massive (20x)
CPU scores: 36818
CPU_01 - 2.46 sec - Booleans and Contours
CPU_02 - 0.83 sec - Twist and Taper (UDT)
CPU_03 - 1.83 sec - Meshing Mini
CPU_04 - 0.06 sec - Extract Render Mesh
CPU_05 - 0.02 sec - Join Render Mesh
CPU_06 - 5.60 sec - Reduce Mesh
CPU_07 - 0.71 sec - Calculating Technical display
CPU_08 - 2.07 sec - Making Silhouettes
ASUS
System Product Name
NVIDIA GeForce RTX 4090 - 4095.0 MB
DriverVersion: 31.0.15.3667
13th Gen Intel(R) Core™ i9-13900K
NumberOfCores: 24 NumberOfLogicalProcessors: 32
MaxClockSpeed: 3.0 GHz
TotalPhysicalMemory: 64.0 GB
Microsoft Windows 11 Pro
  • None - 64-bit
Rhino 7 sr 32 64 bit
AA level = 4
